Zum Hauptinhalt wechseln
2012 Chevy Equinox Tail Light Bulb Replacement
Was du brauchst
  1. 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: Schritt 1, Bild 1 von 3 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: Schritt 1, Bild 2 von 3 2012 Chevy Equinox Tail Light Bulb Replacement, Tail Light Bulb: Schritt 1, Bild 3 von 3
    • Open the trunk of your car.
  2. 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 2, Bild 1 von 3 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 2, Bild 2 von 3 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 2, Bild 3 von 3
    • Remove the two plastic caps by placing a spudger in the bottom opening and gently prying upward.
  3. 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 3, Bild 1 von 3 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 3, Bild 2 von 3 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 3, Bild 3 von 3
    • Remove the two 6 mm Phillips #2 screws located underneath each of the plastic caps by twisting counterclockwise.
  4. 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 4, Bild 1 von 3 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 4, Bild 2 von 3 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 4, Bild 3 von 3
    • Hold the latch down firmly and pull the tail light cover off the vehicle.
    • You may have to apply a back and forth force to remove the cover.
  5. 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 5, Bild 1 von 3 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 5, Bild 2 von 3 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 5, Bild 3 von 3
    • Remove the light bulb socket from the vehicle by gently twisting and pulling it out of the tail light cover.
  6. 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 6, Bild 1 von 3 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 6, Bild 2 von 3 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 6, Bild 3 von 3
    • Twist the light bulb counterclockwise and pull to remove it from the socket.
  7. 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 7, Bild 1 von 3 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 7, Bild 2 von 3 2012 Chevy Equinox Tail Light Bulb Replacement: Schritt 7, Bild 3 von 3
    • Insert the new light bulb by gently pushing the light bulb into the socket and twisting clockwise.
    • When reassembling, make sure to align the tail light cover up to the back of the vehicle before pushing the cover back on.
Abschluss
Kelly Dixon
145 Reputation
1 Anleitung geschrieben
Texas Tech, Team S9-G2, Cowan Fall 2020 Mitglied von Texas Tech, Team S9-G2, Cowan Fall 2020
TTU-COWAN-F20S9G2
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 54
Insgesamt: 1,868
