Einleitung
Make sure that the car has been off for 15 minutes because the brake light bulb may be hot.
Was du brauchst
Locate plastic fasteners and remove with door panel remove tool/flathead by prying them off
On the inside of the trunk remove the side panel to locate the brake light bulb
Remove brake light from housing by pulling it out gently and replace with new bulb
To reassemble your taillight bulb, follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
