Einleitung
This guide will show you how to change a worn out headlight bulb for a 2012 Ford Fusion as quickly as possible
Was du brauchst
The front hood will open and be caught by a saftey latch. Run fingers under the hood and push the latch to the left to open the hood completely
Remove negative terminal from the battery using a 10mm socket. Remove the bolt that is holding the negative terminal and pull terminal off the battery.
Locate the headlight bulb in the front of the car under the hood and twist off the cap covering the headlight bulb
To reassemble your headlight, follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
5 Kommentare
What about the left side?
I agree with both previous comments. your efforts are INCOMPLETE.
What about the left side(PASSENGER SIDE THAT IS)
You only showed the one semi easy to reach(DRIVER’S SIDE, THAT IS)
Yea this guide is incomplete and not helpful.
what years do the head lite assy match with on 2012 ford fusion sle
