Zum Hauptinhalt wechseln
2012 Honda Civic EX Cabin Air Filter Replacement
Was du brauchst
  1. 2012 Honda Civic EX Cabin Air Filter Replacement, Cabin Air Filter: Schritt 1, Bild 1 von 1
    • Open the front passenger side door.
  2. 2012 Honda Civic EX Cabin Air Filter Replacement: Schritt 2, Bild 1 von 1
    • Open the glove compartment box.
    • Make sure the glove compartment is empty.
  3. 2012 Honda Civic EX Cabin Air Filter Replacement: Schritt 3, Bild 1 von 2 2012 Honda Civic EX Cabin Air Filter Replacement: Schritt 3, Bild 2 von 2
    • Find the black pin on the side of the glove compartment and push it in with a spudger.
    • The glove compartment will fall onto floor of the car.
  4. 2012 Honda Civic EX Cabin Air Filter Replacement: Schritt 4, Bild 1 von 1
    • Push the sides of the cabin air filter cover to reveal the filter.
  5. 2012 Honda Civic EX Cabin Air Filter Replacement: Schritt 5, Bild 1 von 1
    • Remove the cabin air filter.
  6. 2012 Honda Civic EX Cabin Air Filter Replacement: Schritt 6, Bild 1 von 1
    • Replace with new air cabin filter.
  7. 2012 Honda Civic EX Cabin Air Filter Replacement: Schritt 7, Bild 1 von 1
    • Put the air filter cover back on.
  8. 2012 Honda Civic EX Cabin Air Filter Replacement: Schritt 8, Bild 1 von 1
    • Push the glove compartment back into place.
  9. 2012 Honda Civic EX Cabin Air Filter Replacement: Schritt 9, Bild 1 von 1
    • Close the door.
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
Kaila51-6
193 Reputation
1 Anleitung geschrieben
Ein Kommentar
"The most important signs of needing to replace the air filter include:
Reduced fuel efficiency
Check engine light is on
Strange engine sounds"
These have nothing to do with the cabin air filter only the engine air intake filter
Xion Carguy - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 19
Letzte 30 Tage: 87
Insgesamt: 743
