Zum Hauptinhalt wechseln
2013-2020 Nissan Rogue Oil and Oil Filter Replacement
Was du brauchst
  1. 2013-2020 Nissan Rogue Oil and Oil Filter Replacement, Oil and Oil Filter Replacement: Schritt 1, Bild 1 von 3 2013-2020 Nissan Rogue Oil and Oil Filter Replacement, Oil and Oil Filter Replacement: Schritt 1, Bild 2 von 3 2013-2020 Nissan Rogue Oil and Oil Filter Replacement, Oil and Oil Filter Replacement: Schritt 1, Bild 3 von 3
    • On a flat, level surface, position the jack behind the front driver-side wheel so that it pushes the car up by the metal frame.
    • Place wheel chocks behind the front passenger-side wheel and the rear drive-side wheel.
    • Lift the car enough for you to be able to safely fit underneath it then fit the jack stand underneath it.
    • Place the jack stand next to where the jack is placed, and extend the jack stand so that it is right under the frame.
    • Gently lower the car so that it is resting all of its weight on the jack stand.
    • Keep the car jack positioned right under the frame as a back-up.
    • Do not get under the car if there is any other person or pet in the vehicle as this can cause the vehicle to fall, leading to serious injury or death.
    • For more information on how to lift the car with a jack and use jack stands follow this guide.
  2. 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 2, Bild 1 von 2 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 2, Bild 2 von 2
    • Come to the front of the car.
    • Place a mat or cushion underneath the car to lay on.
    • Place newspaper or rags beneath the oil drain plug to catch any potential
    • Center your oil drain pan on the ground beneath the oil drain plug.
  3. 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 3, Bild 1 von 3 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 3, Bild 2 von 3 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 3, Bild 3 von 3
    • With your 14 mm socket attached, use the socket ratchet wrench to loosen the oil drain plug by turning it counter-clockwise.
    • Once loose, use your hand to fully remove the drain plug.
    • You may want to wear latex gloves to avoid getting oil on your hands.
    • Wait a few minutes for the majority of the oil to drain into the pan.
  4. 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 4, Bild 1 von 1
    • Reinstall the oil drain plug.
  5. 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 5, Bild 1 von 3 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 5, Bild 2 von 3 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 5, Bild 3 von 3
    • Locate the oil filter behind the trim plastic on the passenger-side of the car.
    • Position the oil drain pan under the oil filter.
  6. 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 6, Bild 1 von 3 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 6, Bild 2 von 3 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 6, Bild 3 von 3
    • Slowly remove the oil filter by hand, or with a strap wrench if necessary.
    • Allow the oil to drain from the oil filter into the drain pan.
    • Once most of the oil has stopped leaking from the oil filter, remove it completely.
    • Place old oil filter to the side on some paper towels to avoid spill.
  7. 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 7, Bild 1 von 2 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 7, Bild 2 von 2
    • Put some new or old oil on the rubber gasket of the new oil filter to create a better seal.
    • Screw on the new oil filter by hand until snug.
    • Be sure not to overtighten the filter, or it will be near-impossible to remove come your next oil change.
  8. 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 8, Bild 1 von 3 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 8, Bild 2 von 3 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 8, Bild 3 von 3
    • Remove the engine oil cap and place a funnel inside.
    • Slowly pour 4.9 quarts of SAE 5W-30 oil into a funnel placed in the oil fill hole.
    • Do not overfill with oil.
  9. 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 9, Bild 1 von 2 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 9, Bild 2 von 2
    • Pull the oil dip stick all the way out and, without checking, wipe it clean with a paper towel.
    • Place the dip stick back.
    • Pull the dip stick out again and verify the oil level.
    • It should come up to right below the second hole from the tip.
    • Add oil as needed.
  10. 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 10, Bild 1 von 1
    • Remove all parts and tools from underneath the car.
    • Use the jack to raise the car off of the jack stand(s).
    • Remove the jack stand(s).
    • Gently lower the car back onto the ground.
  11. 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 11, Bild 1 von 3 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 11, Bild 2 von 3 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 11, Bild 3 von 3
    • Enter the car.
    • On the dash board, use the right selector wheel and rotate it until the settings page is shown.
    • Press the selector peg.
    • With the selector peg, rotate the highlighted option to "maintenance."
    • Scroll to "service" and press the peg.
    • Scroll to "reset" and press the peg.
  12. 2013-2020 Nissan Rogue Oil and Oil Filter Replacement: Schritt 12, Bild 1 von 1
    • Gently pull the oil drain pan out from under the car with care not to spill.
    • Use a funnel to pour the used oil into an oil safe, sealable container if your oil pan is not sealable.
    • Allow 12-24 hours for all of the oil to drain out of the old oil filter.
    • Most auto parts stores and repair shops accept these at no charge to you. In addition, some cities and/or counties have a service where they will collect used oil and filters from your home. For more information, see the American Petroleum Institute's web page on used motor oil collection and recycling.
    • Do not dispose of the used oil in the trash or down a drain. It's terrible for the environment, and illegal!
Ziellinie
University of Memphis, Team 51-12, Kim Fall 2022 Mitglied von University of Memphis, Team 51-12, Kim Fall 2022
UM-KIM-F22S51G12
1 Mitglied
2 Anleitungen geschrieben
4 Kommentare
The oil is not 5W30, it's OW20.
Cameron Indeck - Antwort
Cameron is indeed correct!
Vet eran (HwyFuzz) -
My manual says 5w30 for my 2013 Rogue S AWD....
back to you Cameron
Dick - Antwort
My my....now boys....my Dick is right this time...or maybe we are ALL correct, depending on the year?
Dick - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 34
Letzte 7 Tage: 254
Letzte 30 Tage: 1,191
Insgesamt: 13,745
