Zum Hauptinhalt wechseln
2013-2016 Scion FRS (Toyota gt86) Engine Air Filter Replacement
Was du brauchst
  1. 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement, Engine Air Filter: Schritt 1, Bild 1 von 3 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement, Engine Air Filter: Schritt 1, Bild 2 von 3 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement, Engine Air Filter: Schritt 1, Bild 3 von 3
    • Pull the handle located near the driver's left leg to unlock the hood.
    • Pull the secondary latch located to the right of the emblem.
    • Prop up the hood.
    • Make sure you're not working in a high wind area, as that might blow the hood backward and damage your vehicle.
  2. 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: Schritt 2, Bild 1 von 1
    • Locate the air filter box, which can be found to the front right of the car.
  3. 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: Schritt 3, Bild 1 von 3 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: Schritt 3, Bild 2 von 3 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: Schritt 3, Bild 3 von 3
    • Pull the metal clips up from the top. They will pop out.
  4. 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: Schritt 4, Bild 1 von 3 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: Schritt 4, Bild 2 von 3 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: Schritt 4, Bild 3 von 3
    • Grab the back of the box and pull it towards the top.
    • To pull out the air-filter, simply pull it away from the car and lift up.
  5. 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: Schritt 5, Bild 1 von 1
    • Repeat the process in reverse to install the air filter.
    • Make sure that the tabs on the filter are on the bottom.
  6. 2013-2016 Scion FRS (Toyota gt86)  Engine Air Filter Replacement: Schritt 6, Bild 1 von 1
    • Line up the little pins on the cover of the box with the base of the box in order to close it.
    • Clip the pins back in and you're done!
Abschluss
Now that the new filter is installed, you're good to go.
Mark Symonenko
133 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 14
Letzten 30 Tage: 71
Insgesamt: 2,056
