Einleitung
In these steps, you will learn how to change a Nissan Altima light bulb the quick and easy way using household tools. Note: wear gloves if need. Fix can get very dirty.
Was du brauchst
Turn the steering wheel all the way to the left or right to grant access to the fender line. (Or in our case for better display, remove the wheel.)
Remove the fender liner using flathead screwdrivers by unscrewing all 3 locations holding fender liner to front bumper.
Now go to the underside of the fender liner and remove the three bolts using the Phillips screwdriver and flathead for the 1 clip.
Use same flathead screwdriver technique for the flathead highlighted in green.
Grab the small hole on the underside of the fender, and carefully pull the panel out.
This allows you to access the rear of the headlight housing.
Turn the lightbulb holder counter clockwise until it is released from the headlight
Pull up on the tab on the back of the bulb holder and simultaneously pull the light bulb out.
Replace the lightbulb by putting the new in place of the old one that was just removed.
4 weitere Personen haben diese Anleitung absolviert.
