Einleitung
You may have a 2013 GMC Terrain, and your headlight bulb is out. Don't think about taking it to a mechanic because you can do it yourself with just one tool. All you'll need is your new H11 headlight bulb and a T15 Torx screwdriver.
Was du brauchst
Turn the wheels toward the opposite side of the broken headlight.
Go to the Front fender on the side with the broken headlight and find the cover on the fender liner.
Use a T15 Torx screwdriver to remove the screw.
Turn the cover counterclockwise to remove it.
Reach into the hole to find the round cap to the bulb.
Turn it counterclockwise to expose the socket holding the bulb.
Grab your new bulb.
Plug it back into the socket and twist it clockwise in the hole.
Place the inner fender cover over the hole.
Twist the cover clockwise until it's tight
Screw in the Torx screw until it is tight.
Now your headlights should work perfectly.
Eine weitere Person hat diese Anleitung absolviert.
