Zum Hauptinhalt wechseln
2013 Lexus IS250 Front Dome Light Replacement
  1. 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: Schritt 1, Bild 1 von 2 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: Schritt 1, Bild 2 von 2
    • Open the glasses compartment located near the front dome light. This is usually a straightforward latch or button release.
  2. 2013 Lexus IS250 Front Dome Light Replacement: Schritt 2, Bild 1 von 3 2013 Lexus IS250 Front Dome Light Replacement: Schritt 2, Bild 2 von 3 2013 Lexus IS250 Front Dome Light Replacement: Schritt 2, Bild 3 von 3
    • Locate two housings inisde the compartment and gently pry them open using a flathead screwdriver. Take care not to damage the surrounding plastic.
  3. 2013 Lexus IS250 Front Dome Light Replacement: Schritt 3, Bild 1 von 3 2013 Lexus IS250 Front Dome Light Replacement: Schritt 3, Bild 2 von 3 2013 Lexus IS250 Front Dome Light Replacement: Schritt 3, Bild 3 von 3
    • Utilize a star screwdriver to remove the screws holding the front dome light in place. Ensure a steady hand to prevent any accidental dropping of screws.
  4. 2013 Lexus IS250 Front Dome Light Replacement: Schritt 4, Bild 1 von 3 2013 Lexus IS250 Front Dome Light Replacement: Schritt 4, Bild 2 von 3 2013 Lexus IS250 Front Dome Light Replacement: Schritt 4, Bild 3 von 3
    • With both hands wiggle both sides of the dome. Apply a bit of force at the top to release it from its position. Be cautious to not break the plastic clips securing it.
  5. 2013 Lexus IS250 Front Dome Light Replacement: Schritt 5, Bild 1 von 3 2013 Lexus IS250 Front Dome Light Replacement: Schritt 5, Bild 2 von 3 2013 Lexus IS250 Front Dome Light Replacement: Schritt 5, Bild 3 von 3
    • Inside, youll find two bulbs on both ends. Twist them to unlock and carefully remove.
  6. 2013 Lexus IS250 Front Dome Light Replacement: Schritt 6, Bild 1 von 2 2013 Lexus IS250 Front Dome Light Replacement: Schritt 6, Bild 2 von 2
    • Carefully remove bulb. Recommended to use gloves as it can be difficult to get a grip.
  7. 2013 Lexus IS250 Front Dome Light Replacement: Schritt 7, Bild 1 von 3 2013 Lexus IS250 Front Dome Light Replacement: Schritt 7, Bild 2 von 3 2013 Lexus IS250 Front Dome Light Replacement: Schritt 7, Bild 3 von 3
    • Replace these bulbs with LED alternatives, inserting them and securing by twisting.
  8. 2013 Lexus IS250 Front Dome Light Replacement: Schritt 8, Bild 1 von 1
    • Confirm that the bulbs are functioning by checking if the lights turn on. If not double check the alignment of the bulbs to ensure proper contact.
    • Carefully place the dome back into its original position. Ensure it aligns correctly with the plastic tips. Apply gentle pressure until it clicks back into place.
Abschluss
Christian
157 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 5-3, Kershman Fall 2023 Mitglied von CSU Los Angeles, Team 5-3, Kershman Fall 2023
CSULA-KERSHMAN-F23S5G3
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 41
Insgesamt: 137
