Zum Hauptinhalt wechseln
2013 Nissan Rogue Key Fob Battery Replacement
Was du brauchst
  1. 2013 Nissan Rogue Key Fob Battery Replacement, 2013 Nissan Rogue Key Fob Battery: Schritt 1, Bild 1 von 2 2013 Nissan Rogue Key Fob Battery Replacement, 2013 Nissan Rogue Key Fob Battery: Schritt 1, Bild 2 von 2
    • Slide the small tab on the back of your fob to the left.
    • While holding the tab to the left, pull the metal key out from the top of your fob.
    Frag FixBot
  2. 2013 Nissan Rogue Key Fob Battery Replacement: Schritt 2, Bild 1 von 1
    • Insert your opening pick into the small gap between the two halves of the fob and lightly pry until they separate.
    Frag FixBot
  3. 2013 Nissan Rogue Key Fob Battery Replacement: Schritt 3, Bild 1 von 3 2013 Nissan Rogue Key Fob Battery Replacement: Schritt 3, Bild 2 von 3 2013 Nissan Rogue Key Fob Battery Replacement: Schritt 3, Bild 3 von 3
    • Pull the two halves of the fob apart.
    • Remove the two internal housings.
    Frag FixBot
  4. 2013 Nissan Rogue Key Fob Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery.
    Frag FixBot
  5. 2013 Nissan Rogue Key Fob Battery Replacement: Schritt 5, Bild 1 von 3 2013 Nissan Rogue Key Fob Battery Replacement: Schritt 5, Bild 2 von 3 2013 Nissan Rogue Key Fob Battery Replacement: Schritt 5, Bild 3 von 3
    • Lightly saturate a cotton swab with 70% isopropyl alcohol and wipe down the inside of the shells and the rubber pad.
    • For any small crevices dip, the toothpick into the alcohol and clean any dirt or debris.
    • Avoid wiping the circuit board and any metal components.
    Frag FixBot
  6. 2013 Nissan Rogue Key Fob Battery Replacement: Schritt 6, Bild 1 von 1
    • Once the alcohol is dried, place a new battery into the battery housing with the proper orientation.
    Frag FixBot
  7. 2013 Nissan Rogue Key Fob Battery Replacement: Schritt 7, Bild 1 von 3 2013 Nissan Rogue Key Fob Battery Replacement: Schritt 7, Bild 2 von 3 2013 Nissan Rogue Key Fob Battery Replacement: Schritt 7, Bild 3 von 3
    • Replace the internal components and click the two halves of the fob back together.
    Frag FixBot
  8. 2013 Nissan Rogue Key Fob Battery Replacement: Schritt 8, Bild 1 von 2 2013 Nissan Rogue Key Fob Battery Replacement: Schritt 8, Bild 2 von 2
    • Slide your key back into its housing.
    Frag FixBot
Abschluss
Your fob should now be fully functional!
Eine weitere Person hat diese Anleitung absolviert.
3 Kommentare zur Anleitung
OMG… I wish I had read this before and attempted to take my key fob apart. I’ve got it all scraped up and ugly from them telling me to use a screwdriver….never mind just do exacty everything this post tells you. I had no problems opening the key fob once I read this article .
Trust me do as this tells you step by step. Just don’t use a screwdriver as another on the www will inform you to do.
Thank you so much for posting this key fob battery replacement info.
Pamela Parker - Antwort Teilen
Thanks worked perfectly and as stated above don't use a screwdriver I also read that but thank goodness I didn't have one
brandy france - Antwort Teilen
My son is trying to fix a rogue for me to drive in winter. It was running but his buddy left the key in the ignition when he got out for the night. He forgot the key was in the ignition and tried starting it with the other key. Now it won't start. Had a key guy come out and that didnt help plus has new battery. Really need this car for winter. How can we fix this
MARGARET Brown - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 65
Insgesamt: 5,982
