Einleitung
If one of the rear blinker lights on your 2013 Volkswagen Passat has burned out, or maybe you want brighter and longer lasting LED light bulbs for your car, then use this guide to replace the rear blinker lights.
A proper functioning blinker light tells the drivers behind your vehicle what you plan on doing, as well as bringing you to the attention of drivers if your on the side of the road through the hazard lights.
Before using this guide, make sure to purchase the replacement light bulbs. LED light bulbs have proven to be brighter, more efficient, and longer lasting. The only downside an LED has to a traditional light bulb is price, as LED’s tend to be more expensive. The choice is up to you.
Although no tools are required, a small, wet rag helps clean up some old and grimy dust. A flashlight can also be used if sufficient light isn’t available.
Before starting this guide, be sure to park the vehicle in a safe and well-lit location, and preferably in the shade to keep yourself cool while working.
Was du brauchst
Open your trunk and find the access panel.
The access panel will be located around the corner of the indent. It is in a similar position on the opposite side as well.
Look around for the access panel as it might blend in well with the rest of the trunk.
Once found, pull back the access panel to reveal the rear components of the tail light assembly.
Rotate the plastic screw counter-clockwise until the screw becomes loose.
Remove the plastic screw.
Remove the tail light from the rear of the vehicle by pulling it away from the vehicle.
Undo all 4 clips securing the grey plastic piece to the red plastic piece.
Lift up and separate the grey piece from the red piece.
When inserting the new light bulb, line up the notches with the cutouts and insert the light bulb.
Once the light bulb has been inserted, rotate counter-clockwise to secure the light bulb.
To reinstall the taillight assembly, simply follow these instructions in reverse order.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Best DIY instructions I’ve ever followed.
Thank you! The instruction had all the necessary details and really easy to follow!
