Zum Hauptinhalt wechseln
2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement
Was du brauchst
  1. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement, COMAND Centre-Dial Touchpad: Schritt 1, Bild 1 von 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement, COMAND Centre-Dial Touchpad: Schritt 1, Bild 2 von 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement, COMAND Centre-Dial Touchpad: Schritt 1, Bild 3 von 3
    • Start by pressing down on the button that opens the center arm-rest.
    • Pop each side of the silver trim using the trim removal tool or a plastic opening tool.
    • Remove the silver trim.
  2. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: Schritt 2, Bild 1 von 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: Schritt 2, Bild 2 von 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: Schritt 2, Bild 3 von 3
    • Remove the two 20 mm screws securing the center console with a T20 Torx screwdriver.
  3. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: Schritt 3, Bild 1 von 2 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: Schritt 3, Bild 2 von 2
    • Make sure there aren't any loose articles in the center storage compartment.
    • Lift the end of the center-console and flip it to reveal the undercarriage of the center-dial touchpad and its wirings.
  4. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: Schritt 4, Bild 1 von 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: Schritt 4, Bild 2 von 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: Schritt 4, Bild 3 von 3
    • Press your thumb on the safety tab to remove each blue connection.
  5. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: Schritt 5, Bild 1 von 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: Schritt 5, Bild 2 von 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: Schritt 5, Bild 3 von 3
    • Press down on the center of the white connection in the middle and slide the safety latch to the left to pull out the main white connection.
  6. 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: Schritt 6, Bild 1 von 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: Schritt 6, Bild 2 von 3 2014-2020 Mercedes-Benz C-Class W205 COMAND Centre-Dial Touchpad Replacement: Schritt 6, Bild 3 von 3
    • Remove the two 15 mm T15 Torx screws holding the center-dial touchpad.
    • Firmly press the center-dial touchpad out to remove the unit.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Amin Fadhil
243 Reputation
1 Anleitung geschrieben
York University, Team S1-G87, Woodhouse Fall 2020 Mitglied von York University, Team S1-G87, Woodhouse Fall 2020
YORK-WOODHOUSE-F20S1G87
1 Mitglied
Ein Kommentar
This is great thanks, made an account to say thank you
Nolan Scott - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 41
Letzte 30 Tage: 181
Insgesamt: 11,151
