Zum Hauptinhalt wechseln
2014-2016 Toyota Corolla Engine Air Filter Replacement
Was du brauchst
  1. 2014-2016 Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: Schritt 1, Bild 1 von 2 2014-2016 Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: Schritt 1, Bild 2 von 2
    • Open the hood of your Corolla by pulling the hinge at the bottom of your dash and hold it up using the hood lift support.
    • Pull the hinge in the lower part of your driver-side dashboard. It should have an icon of a vehicle with its hood up.
    • Once you pull it, open up the hood and use the support located at the center of the engine bay to hold the hood up.
  2. 2014-2016 Toyota Corolla Engine Air Filter Replacement: Schritt 2, Bild 1 von 3 2014-2016 Toyota Corolla Engine Air Filter Replacement: Schritt 2, Bild 2 von 3 2014-2016 Toyota Corolla Engine Air Filter Replacement: Schritt 2, Bild 3 von 3
    • Find air filter box and unclip the clips on the air filter's sides.
    • Take your hand to the clips and pull them slightly. You can remove the top of the air filter box if done right.
  3. 2014-2016 Toyota Corolla Engine Air Filter Replacement: Schritt 3, Bild 1 von 2 2014-2016 Toyota Corolla Engine Air Filter Replacement: Schritt 3, Bild 2 von 2
    • Hold the air filter top up and pull out the old air filter.
    • Once old air filter is removed, get your new one and line up the square corner of the filter with the square corner of the air filter box.
    • Insert the new air filter with this orientation.
  4. 2014-2016 Toyota Corolla Engine Air Filter Replacement: Schritt 4, Bild 1 von 3 2014-2016 Toyota Corolla Engine Air Filter Replacement: Schritt 4, Bild 2 von 3 2014-2016 Toyota Corolla Engine Air Filter Replacement: Schritt 4, Bild 3 von 3
    • Clip back the clips on the sides of the air filter box to close it.
    • Congratulations, you have successfully replaced the air filter in your Corolla.
Abschluss
Congratulations, you have replaced the air filter in your Corolla.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Romer Pena
136 Reputation
1 Anleitung geschrieben
Austin Community College, Team 1-10, Meigs Fall 2023 Mitglied von Austin Community College, Team 1-10, Meigs Fall 2023
AUSTINCC-MEIGS-F23S1G10
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 64
Insgesamt: 272
