Einleitung
This guide will help you to replace the headlight bulb in your 2014 Chevy Cruze. Your headlights play a crucial role in driver safety; however, sometimes they burn out. Luckily, the solution is quick and easy.
Be sure to turn off your car and engage the parking brake.
Was du brauchst
Open the hood of your Chevy Cruze. The headlight bulbs are shown in the image.
Put on rubber gloves.
Twist the headlight bulb counterclockwise until you can pull it from its socket.
Using a prying tool, push the gray locking mechanism back until it is completely removed.
