Zum Hauptinhalt wechseln
2014 Chevy Cruze Headlight Bulb Replacement
Was du brauchst
  1. 2014 Chevy Cruze Headlight Bulb Replacement, Headlight Bulb: Schritt 1, Bild 1 von 1
    • Open the hood of your Chevy Cruze. The headlight bulbs are shown in the image.
  2. 2014 Chevy Cruze Headlight Bulb Replacement: Schritt 2, Bild 1 von 1
    • Put on rubber gloves.
    • Twist the headlight bulb counterclockwise until you can pull it from its socket.
  3. 2014 Chevy Cruze Headlight Bulb Replacement: Schritt 3, Bild 1 von 1
    • Using a prying tool, push the gray locking mechanism back until it is completely removed.
    • The locking mechanism can be removed by sliding it in the opposite direction from the headlight bulb.
  4. 2014 Chevy Cruze Headlight Bulb Replacement: Schritt 4, Bild 1 von 1
    • Pull the old headlight bulb from the green socket.
Abschluss
Caiden
109 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 41
Letzte 30 Tage: 215
Insgesamt: 6,147
