Zum Hauptinhalt wechseln
2014 Mercedes C230 Front Parking Light Replacement
Was du brauchst
  1. 2014 Mercedes C230 Front Parking Light Replacement, Front Parking Light: Schritt 1, Bild 1 von 2 2014 Mercedes C230 Front Parking Light Replacement, Front Parking Light: Schritt 1, Bild 2 von 2
    • Turn off the car lights.
  2. 2014 Mercedes C230 Front Parking Light Replacement: Schritt 2, Bild 1 von 2 2014 Mercedes C230 Front Parking Light Replacement: Schritt 2, Bild 2 von 2
    • Open the car hood by pulling the red lever placed under the light switch.
  3. 2014 Mercedes C230 Front Parking Light Replacement: Schritt 3, Bild 1 von 2 2014 Mercedes C230 Front Parking Light Replacement: Schritt 3, Bild 2 von 2
    • Pull the lever outside of your car and open the hood.
  4. 2014 Mercedes C230 Front Parking Light Replacement: Schritt 4, Bild 1 von 3 2014 Mercedes C230 Front Parking Light Replacement: Schritt 4, Bild 2 von 3 2014 Mercedes C230 Front Parking Light Replacement: Schritt 4, Bild 3 von 3
    • Press the clamp on one side of the light cover and pull it open.
    • The light cover is located behind the car headlight.
  5. 2014 Mercedes C230 Front Parking Light Replacement: Schritt 5, Bild 1 von 2 2014 Mercedes C230 Front Parking Light Replacement: Schritt 5, Bild 2 von 2
    • Pull the smaller lamp out. It has a grey wire attached to it.
  6. 2014 Mercedes C230 Front Parking Light Replacement: Schritt 6, Bild 1 von 2 2014 Mercedes C230 Front Parking Light Replacement: Schritt 6, Bild 2 von 2
    • Pull out the old light bulb and replace it with the new one.
  7. 2014 Mercedes C230 Front Parking Light Replacement: Schritt 7, Bild 1 von 1
    • Check if the light is working.
  8. 2014 Mercedes C230 Front Parking Light Replacement: Schritt 8, Bild 1 von 1
    • Put the light cover back in place.
Abschluss
Daniil Bendatii
157 Reputation
1 Anleitung geschrieben
York University, Team S1-G2, O'Regan Summer 2021 Mitglied von York University, Team S1-G2, O'Regan Summer 2021
YORK-O'REGAN-SU21S1G2
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 12
Letzte 30 Tage: 46
Insgesamt: 1,386
