Einleitung
If your 2014 Subaru Impreza Hatchback's brake lights aren't lighting up, use this guide to replace the brake lights of the vehicle. This procedure does not require any special equipment or any expertise in home improvement.
One of the most common reasons for this issue to occur is because the fuse in the bulb has either burnt out or the bulb's connectors have become faulty. These problems can be mitigated by replacing the bulb with a new one.
Before beginning, make sure to turn off the car's engine.
Was du brauchst
Unscrew the both the 2 cm Phillips #3 screws encircled in the image shown with a Phillips #3 screw driver.
Unscrew both the 2 cm Phillips #3 screws by turning the screwdriver counterclockwise.
Upon opening the brake light, you should see three bulbs in total.
The brake light is the one on the bottom.
Reinsert the bulb back into its initial position.
Gently twist the bulb clockwise to further tighten the bulb.
Reattach both the 2 cm Phillips #3 screws back into their place by screwing them clockwise with your Phillips #3 screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
