Zum Hauptinhalt wechseln
2015 Jeep Patriot Tail/ Brake Light Replacement
Was du brauchst
  1. 2015 Jeep Patriot Tail/ Brake Light Replacement, Jeep Patriot Tail/ Brake Light Replacement: Schritt 1, Bild 1 von 2 2015 Jeep Patriot Tail/ Brake Light Replacement, Jeep Patriot Tail/ Brake Light Replacement: Schritt 1, Bild 2 von 2
    • Open the trunk and locate the fender clips.
    • These are located near the tail lights.
  2. 2015 Jeep Patriot Tail/ Brake Light Replacement: Schritt 2, Bild 1 von 3 2015 Jeep Patriot Tail/ Brake Light Replacement: Schritt 2, Bild 2 von 3 2015 Jeep Patriot Tail/ Brake Light Replacement: Schritt 2, Bild 3 von 3
    • Use the 3/16 inch flathead screwdriver to remove the top fender clip holding the tail light on.
  3. 2015 Jeep Patriot Tail/ Brake Light Replacement: Schritt 3, Bild 1 von 1
    • Remove the lower fender clip.
    • This will release the tail light so be careful.
  4. 2015 Jeep Patriot Tail/ Brake Light Replacement: Schritt 4, Bild 1 von 2 2015 Jeep Patriot Tail/ Brake Light Replacement: Schritt 4, Bild 2 von 2
    • Remove the tail light to expose the light bulb.
  5. 2015 Jeep Patriot Tail/ Brake Light Replacement: Schritt 5, Bild 1 von 2 2015 Jeep Patriot Tail/ Brake Light Replacement: Schritt 5, Bild 2 von 2
    • Twist the light bulb to remove it from the holder.
    • Replace the old bulb with the new one. make sure to twist the new bulb to secure it.
    • Do not touch the new light bulb with your bare hands as the oil from your fingers will cause it to degrade faster and possibly shatter.
  6. 2015 Jeep Patriot Tail/ Brake Light Replacement: Schritt 6, Bild 1 von 2 2015 Jeep Patriot Tail/ Brake Light Replacement: Schritt 6, Bild 2 von 2
    • Align the two pegs on the tail light housing with the matching holes on the car.
  7. 2015 Jeep Patriot Tail/ Brake Light Replacement: Schritt 7, Bild 1 von 2 2015 Jeep Patriot Tail/ Brake Light Replacement: Schritt 7, Bild 2 von 2
    • Reinsert the top and bottom fender clips.
Abschluss
Yadira Vera
145 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 1-7, Briggs Fall 2022 Mitglied von CSU Los Angeles, Team 1-7, Briggs Fall 2022
CSULA-BRIGGS-F22S1G7
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 29
Letzte 30 Tage: 161
Insgesamt: 2,644
