Zum Hauptinhalt wechseln
2015 Toyota Highlander Cabin Air Filter Replacement
Was du brauchst
  1. 2015 Toyota Highlander Cabin Air Filter Replacement, 2015 Toyota Highlander Cabin Air Filter: Schritt 1, Bild 1 von 1
    • Make sure car is off by removing key or moving it to the off position as shown.
    Frag FixBot
    Kommentar hinzufügen
  2. 2015 Toyota Highlander Cabin Air Filter Replacement: Schritt 2, Bild 1 von 2 2015 Toyota Highlander Cabin Air Filter Replacement: Schritt 2, Bild 2 von 2
    • Move to the passenger side of the car and open the passenger side door.
    Frag FixBot
  3. 2015 Toyota Highlander Cabin Air Filter Replacement: Schritt 3, Bild 1 von 1
    • Open and empty the glovebox.
    Frag FixBot
  4. 2015 Toyota Highlander Cabin Air Filter Replacement: Schritt 4, Bild 1 von 2 2015 Toyota Highlander Cabin Air Filter Replacement: Schritt 4, Bild 2 von 2
    • Detach the latch at the lower right-hand side of the glovebox.
    • Pull it outwards and unclip it with your finger as shown.
    Frag FixBot
  5. 2015 Toyota Highlander Cabin Air Filter Replacement: Schritt 5, Bild 1 von 1
    • Push in both upper sides of the glovebox to unhook the stops.
    • This should cause the entire glovebox to come down and detach.
    Frag FixBot
  6. 2015 Toyota Highlander Cabin Air Filter Replacement: Schritt 6, Bild 1 von 1
    • Remove the front plastic cover as shown. Pull on both upper tabs using your fingers.
    Frag FixBot
  7. 2015 Toyota Highlander Cabin Air Filter Replacement: Schritt 7, Bild 1 von 1
    • Swing down the front plastic cover.
    • Unhook the tabs from both sides of the rear plastic cover and pull it out.
    Frag FixBot
  8. 2015 Toyota Highlander Cabin Air Filter Replacement: Schritt 8, Bild 1 von 2 2015 Toyota Highlander Cabin Air Filter Replacement: Schritt 8, Bild 2 von 2
    • Remove the old cabin air filter from the vehicle.
    • Clean any debris found in the cabin air filter compartment.
    Frag FixBot
  9. 2015 Toyota Highlander Cabin Air Filter Replacement: Schritt 9, Bild 1 von 1
    • Insert the new cabin air filter into the compartment.
    • Be mindful of the airflow direction arrow. The airflow arrow should point upwards as shown.
    Frag FixBot
Abschluss
Prabhmeet Brar
178 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 11-13, Grodsky Fall 2021 Mitglied von CSU Los Angeles, Team 11-13, Grodsky Fall 2021
CSULA-GRODSKY-F21S11G13
1 Mitglied
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 77
Insgesamt: 2,447
