Zum Hauptinhalt wechseln
2016-2021 Chevrolet Camaro Brake Light Bulb Replacement
Was du brauchst
  1. 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement, Brake/reverse light bulb: Schritt 1, Bild 1 von 2 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement, Brake/reverse light bulb: Schritt 1, Bild 2 von 2
    • Using either the button on your vehicle's key fob, or the button on the driver's side door, open the trunk.
    • ​ Go to the rear of the vehicle and lift the rear trunk lid until it reaches its highest position and locks out.​
  2. 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: Schritt 2, Bild 1 von 3 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: Schritt 2, Bild 2 von 3 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: Schritt 2, Bild 3 von 3
    • Using a spudger, gently pry the covers for the pop-rivets out.
    • Remove the pop-rivets themselves by inserting a spudger underneath them and prying up.​
    • There will be a gap for the head of the spudger on each pop-rivet.
  3. 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: Schritt 3, Bild 1 von 1
    • After the fastener caps have been removed, twist the knob on top of the cover counterclockwise to remove it.
  4. 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: Schritt 4, Bild 1 von 1
    • With the housing assembly open, gently lift the housing cover from the taillight assembly and set it aside.​ ​
  5. 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: Schritt 5, Bild 1 von 3 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: Schritt 5, Bild 2 von 3 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: Schritt 5, Bild 3 von 3
    • Locate the reverse bulb socket; it will be identifiable by a wire running from the back of the tail light.
    • Gently grab the reverse bulb socket with your pliers, then gently turn it counterclockwise for one-quarter of a rotation.
  6. 2016-2021 Chevrolet Camaro Brake Light Bulb Replacement: Schritt 6, Bild 1 von 1
    • Pull the socket out from the assembly, and pull out the old bulb.
    • Insert your new bulb by gently pressing it into the socket.
    • Handle the bulbs very carefully, using a glove so that grease from your hands does not get onto the glass, thus reducing their useful life. Glass can break very easily and cause accidents.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
does not work for 2019 break lights
Emeterio Rivas - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 24
Letzte 30 Tage: 105
Insgesamt: 3,180
