Zum Hauptinhalt wechseln
2016-2021 Honda Civic Headlight Bulb Replacement
Was du brauchst
  1. 2016-2021 Honda Civic Headlight Bulb Replacement, Headlight Bulb: Schritt 1, Bild 1 von 1
    • Pull the latch near the door panel to open the hood (inside the driver's side of the vehicle).
  2. 2016-2021 Honda Civic Headlight Bulb Replacement: Schritt 2, Bild 1 von 1
    • Locate the headlight.
  3. 2016-2021 Honda Civic Headlight Bulb Replacement: Schritt 3, Bild 1 von 3 2016-2021 Honda Civic Headlight Bulb Replacement: Schritt 3, Bild 2 von 3 2016-2021 Honda Civic Headlight Bulb Replacement: Schritt 3, Bild 3 von 3
    • Unplug the connector by pushing down on the top of the tab shown and pull it apart.
    • It should disconnect easily. If there is any resistance than you need to press the tab harder.
  4. 2016-2021 Honda Civic Headlight Bulb Replacement: Schritt 4, Bild 1 von 2 2016-2021 Honda Civic Headlight Bulb Replacement: Schritt 4, Bild 2 von 2
    • Twist the bulb counterclockwise and pull bulb out.
  5. 2016-2021 Honda Civic Headlight Bulb Replacement: Schritt 5, Bild 1 von 2 2016-2021 Honda Civic Headlight Bulb Replacement: Schritt 5, Bild 2 von 2
    • Align the three tabs on the new bulb to the three spaces in the housing for the headlight bulb.
  6. 2016-2021 Honda Civic Headlight Bulb Replacement: Schritt 6, Bild 1 von 1
    • Insert the new bulb and twist clockwise until it clicks.
    • Avoid touching the bulb with your hands as the oil on your hands can be damaging and cause the bulb to fail prematurely.
  7. 2016-2021 Honda Civic Headlight Bulb Replacement: Schritt 7, Bild 1 von 1
    • Reconnect wires to the new bulb.
Abschluss
To reconnect the new bulb follow the instructions in reverse order as shown. If the bulb does not turn on make sure to shut off the car before attempting to fix the bulb.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team S1-G4, O'Connell Spring 2021 Mitglied von UMass Dartmouth, Team S1-G4, O'Connell Spring 2021
UMASSD-O'CONNELL-S21S1G4
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 89
Letzte 30 Tage: 431
Insgesamt: 14,987
