Einleitung
In this guide you will learn how to replace a low beam headlight bulb for the 10th generation 2016-2021 Honda Civic.
Before beginning the repair, turn off your engine and put on your emergency break.
Was du brauchst
Pull the latch near the door panel to open the hood (inside the driver's side of the vehicle).
Unplug the connector by pushing down on the top of the tab shown and pull it apart.
Align the three tabs on the new bulb to the three spaces in the housing for the headlight bulb.
To reconnect the new bulb follow the instructions in reverse order as shown. If the bulb does not turn on make sure to shut off the car before attempting to fix the bulb.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
