Zum Hauptinhalt wechseln
2016 Ford Fiesta S High Beam Replacement
Was du brauchst
    1. 2016 Ford Fiesta S High Beam Replacement, High Beam: Schritt 1, Bild 1 von 3 2016 Ford Fiesta S High Beam Replacement, High Beam: Schritt 1, Bild 2 von 3 2016 Ford Fiesta S High Beam Replacement, High Beam: Schritt 1, Bild 3 von 3
      • Do not open your hood when there are high winds.
      • Verify that the handbrake is on and the ignition is off.
      • Wait 10 minutes for the engine to cool before opening the hood.
      • Locate the release hatch and pull it towards you.
      • Lift the hood slightly and feel for the release catch, then slide it to the left.
      • Lift the hood and prop it up with the strut.
      Frag FixBot
      Kommentar hinzufügen
    2. 2016 Ford Fiesta S High Beam Replacement: Schritt 2, Bild 1 von 1
      • Remove the lower retaining screw with a Phillips screwdriver.
      • Keep the pop rivet in a safe place to help with the reassembling process.
      Frag FixBot
    3. 2016 Ford Fiesta S High Beam Replacement: Schritt 3, Bild 1 von 1
      • Remove the front screw with a flat head screwdriver.
      • Keep the screw in a safe place to help with the reassembling process.
      Frag FixBot
    4. 2016 Ford Fiesta S High Beam Replacement: Schritt 4, Bild 1 von 1
      • Remove the upper retaining screw in the back with a Phillips screwdriver.
      Frag FixBot
    5. 2016 Ford Fiesta S High Beam Replacement: Schritt 5, Bild 1 von 1
      • Lift the headlight up and off the mounting point clip.
      • Squeeze the clips and pull the electrical connector out.
      • Remove the headlight from the back first for easier removal.
      • Place the headlight on a flat, secure surface.
      Frag FixBot
    6. 2016 Ford Fiesta S High Beam Replacement: Schritt 6, Bild 1 von 1
      • Locate the high beam cover in the middle of the headlight.
      • Turn the cover counterclockwise and remove it.
      Frag FixBot
    7. 2016 Ford Fiesta S High Beam Replacement: Schritt 7, Bild 1 von 2 2016 Ford Fiesta S High Beam Replacement: Schritt 7, Bild 2 von 2
      • Turn the bulb and the electrical connector counterclockwise and remove them.
      Frag FixBot
    8. 2016 Ford Fiesta S High Beam Replacement: Schritt 8, Bild 1 von 2 2016 Ford Fiesta S High Beam Replacement: Schritt 8, Bild 2 von 2
      • Make sure you do not touch the glass surface of the bulb with your bare hands; if the oil from your hands touches the glass surface, it may cause the bulb to heat up and burn out.
      • Clean the bulb with rubbing alcohol to remove any oils that may be on the bulb then remove any traces of alcohol with a dry cloth before reinstalling the bulb.
      • Screw in the new bulb clockwise to secure it in place.
      • Put the electrical connector back on.
      • Hold the bulb by its base and insert it back into the back of the headlight.
      • Turn your headlights on to test if the headlight works properly.
      • Screw the cover back on and secure it.
      Frag FixBot
    9. 2016 Ford Fiesta S High Beam Replacement: Schritt 9, Bild 1 von 2 2016 Ford Fiesta S High Beam Replacement: Schritt 9, Bild 2 von 2
      • Position the headlight back into place.
      • Reclip the mounting point clip.
      • Position the headlight so that the front piece is under the pop rivet hole that was removed in Step 2.
      Frag FixBot
    10. 2016 Ford Fiesta S High Beam Replacement: Schritt 10, Bild 1 von 1
      • Screw back in the lower retaining screw.
      Frag FixBot
    11. 2016 Ford Fiesta S High Beam Replacement: Schritt 11, Bild 1 von 1
      • Screw back in the middle screw with a flathead screwdriver.
      Frag FixBot
    12. 2016 Ford Fiesta S High Beam Replacement: Schritt 12, Bild 1 von 1
      • Screw back in the upper retaining screw to secure the back of the headlight.
      Frag FixBot
    13. 2016 Ford Fiesta S High Beam Replacement: Schritt 13, Bild 1 von 1
      • Plug the electrical connector to the back of the headlight.
      Frag FixBot
    14. 2016 Ford Fiesta S High Beam Replacement: Schritt 14, Bild 1 von 1
      • Hold the hood with one hand and release the strut with the other.
      • Let the hood down gently until 30 cm from the body, then drop it to lock the hood.
      • Pushing on the hood to lock it might cause dents.
      Frag FixBot
Ziellinie
4 weitere Personen haben diese Anleitung absolviert.
2 Kommentare zur Anleitung
buen tutorial, estaria excelente agregar un video, gracias por el aporte
oslec “Netmit” burg - Antwort Teilen
Parabéns, muito bom a explicação
Edipeixe - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 46
Letzte 30 Tage: 133
Insgesamt: 12,395
