Zum Hauptinhalt wechseln
2017-2022 Honda CR-V Reverse Light Bulb Replacement
Was du brauchst
  1. 2017-2022 Honda CR-V Reverse Light Bulb Replacement, Reverse Light Bulb: Schritt 1, Bild 1 von 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement, Reverse Light Bulb: Schritt 1, Bild 2 von 2
    • Open the trunk.
  2. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: Schritt 2, Bild 1 von 1
    • Determine which bulb(s) needs to be replaced.
  3. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: Schritt 3, Bild 1 von 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement: Schritt 3, Bild 2 von 2
    • Open the panel with a flathead screwdriver.
    • If you do not have a flathead screwdriver, anything with a flat surface should work.
  4. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: Schritt 4, Bild 1 von 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement: Schritt 4, Bild 2 von 2
    • Hold down tab and remove the cable.
  5. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: Schritt 5, Bild 1 von 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement: Schritt 5, Bild 2 von 2
    • Turn the plug to the left until you hear a click.
  6. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: Schritt 6, Bild 1 von 1
    • Pull the socket out of its housing.
  7. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: Schritt 7, Bild 1 von 1
    • Take the bulb out the socket.
  8. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: Schritt 8, Bild 1 von 1
    • Replace the bulb.
    • Make sure you use the Hella 921TB Bulb 921 12V 16W W2.1X9.5D T5.
  9. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: Schritt 9, Bild 1 von 1
    • Put the plug back into its original position.
  10. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: Schritt 10, Bild 1 von 1
    • Turn plug to the right until secure.
  11. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: Schritt 11, Bild 1 von 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement: Schritt 11, Bild 2 von 2
    • Reinsert the cable.
  12. 2017-2022 Honda CR-V Reverse Light Bulb Replacement: Schritt 12, Bild 1 von 2 2017-2022 Honda CR-V Reverse Light Bulb Replacement: Schritt 12, Bild 2 von 2
    • Reinsert the panel.
Abschluss
This guide tells you how to replace the bulb, and how to put everything back together
Eine weitere Person hat diese Anleitung absolviert.
Hashmat Jadoon
235 Reputation
1 Anleitung geschrieben
York University, Team B-9, Woodhouse Fall 2023 Mitglied von York University, Team B-9, Woodhouse Fall 2023
YORK-WOODHOUSE-F23SBG9
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 17
Letzte 30 Tage: 92
Insgesamt: 379
