Einleitung
Use this guide to replace the reverse light on the Honda CR-V 2018 if it is not working anymore.
A reverse light is crucial for any vehicle as it communicates your actions to other drivers around you, which they can prepare for. If you notice that your reverse light does not work anymore ensure that you replace it as soon as possible as it can be a danger to other and result in you getting fined.
As you are working with a light bulb it can easily shatter so handle it with care when taking out the old one and putting in the new one.
After you finish the replacement have someone check that the light is working by having one person put the car in reverse and one person inspecting the back of the car.
Was du brauchst
This guide tells you how to replace the bulb, and how to put everything back together
Eine weitere Person hat diese Anleitung absolviert.
