Einleitung
In this guide, you will learn how to replace a 2017 Chevrolet Traverse Cabin Air Filter. You should change your vehicle's cabin air filter every 12,000-20,000 miles. Changing your cabin air filter can reduce health risks by filtering out pollens and pollutants, helping reduce odors coming from your vents, and improving air circulation in your vehicle.
Was du brauchst
Using your fingers, twist the two fasteners counterclockwise then pull to remove them.
On the right side of the glove box, there is a damper. Pull the damper up and then out.
Use both hands to pull down on the plastic cabin air filter cover to remove the it.
Pay special attention to the directions on the cabin air filter. The writing should be facing you and the air-flow arrow should be facing downwards.
