Einleitung
This guide will show you how to replace the headlight of a 2017 Honda Accord. Prior knowledge of how to use a ratchet wrench and basic car maintenance is required.
Was du brauchst
Pull the Hood Latch lever inside the car, located under the steering wheel.
Lift the hood while pressing up on the lever under the front of the hood.
Lift up the hood prop rod and insert it into the hole on the underside of the hood.
Use a 1/4" ratcheting wrench and a 10mm socket to loosen the bolt on the negative terminal head.
Lift the terminal up off of the battery and place it to the side.
Use a 1/4" ratcheting wrench, a 6" extension and a 10mm socket to remove the last bolt.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
