Zum Hauptinhalt wechseln
2017 Honda Civic Sport Brake Light Bulb Replacement
Was du brauchst
  1. 2017 Honda Civic Sport Brake Light Bulb Replacement, Brake Light Bulb: Schritt 1, Bild 1 von 3 2017 Honda Civic Sport Brake Light Bulb Replacement, Brake Light Bulb: Schritt 1, Bild 2 von 3 2017 Honda Civic Sport Brake Light Bulb Replacement, Brake Light Bulb: Schritt 1, Bild 3 von 3
    • Turn your vehicle off before beginning.
    • Open your trunk.
    • Use a Phillips #2 screwdriver to remove the two screws securing the shield.
  2. 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 2, Bild 1 von 3 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 2, Bild 2 von 3 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 2, Bild 3 von 3
    • To remove the brake light housing, start from the top of the frame and pull the shield outwards.
  3. 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 3, Bild 1 von 3 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 3, Bild 2 von 3 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 3, Bild 3 von 3
    • Twist the brake light socket counterclockwise and pull it directly out, with care not to damage the wires.
    • The brake light has a gray plug.
  4. 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 4, Bild 1 von 2 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 4, Bild 2 von 2
    • Grip light bulb and slide it directly out of its socket.
  5. 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 5, Bild 1 von 3 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 5, Bild 2 von 3 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 5, Bild 3 von 3
    • Install a new bulb by pressing it into the socket.
    • You'll hear a "click" when it's properly inserted.
  6. 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 6, Bild 1 von 2 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 6, Bild 2 von 2
    • Place the socket back in its housing and twist it clockwise.
  7. 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 7, Bild 1 von 2 2017 Honda Civic Sport Brake Light Bulb Replacement: Schritt 7, Bild 2 von 2
    • Align the brake light shield with the two sockets and firmly press the brake light inward.
    • You'll hear a "pop" when the shield is secured.
Abschluss
Enjoy your functional brake light!
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Theo Chisom
177 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 31
Letzte 30 Tage: 183
Insgesamt: 3,782
