Zum Hauptinhalt wechseln
2017 Kia Niro Headlight Replacement
Was du brauchst
  1. 2017 Kia Niro Headlight Replacement, Headlight: Schritt 1, Bild 1 von 1
    • Open the hood of the vehicle and make sure it is secured to prevent injury.
  2. 2017 Kia Niro Headlight Replacement: Schritt 2, Bild 1 von 1
    • Locate the bulb cover cap which can be found under the hood and directly behind the headlight.
  3. 2017 Kia Niro Headlight Replacement: Schritt 3, Bild 1 von 1
    • Remove the bulb cover cap by rotating it counter-clockwise until it is fully detached.
  4. 2017 Kia Niro Headlight Replacement: Schritt 4, Bild 1 von 1
    • Place the cap in a location that is out of the way of your work area and where you can easily find it.
  5. 2017 Kia Niro Headlight Replacement: Schritt 5, Bild 1 von 1
    • Remove the old bulb by rotating counter-clockwise until it is detached, being careful not to drop the bulb into the hood of the vehicle.
  6. 2017 Kia Niro Headlight Replacement: Schritt 6, Bild 1 von 1
    • Prepare your replacement XtraVision Fog Light/Headlight Bulb 9005XV-2 for installation by removing it from the packaging and ensuring that the bulb is not broken.
  7. 2017 Kia Niro Headlight Replacement: Schritt 7, Bild 1 von 1
    • Insert the new bulb by pushing it into the bulb compartment.
    • Turn the bulb clockwise until it is secure.
  8. 2017 Kia Niro Headlight Replacement: Schritt 8, Bild 1 von 1
    • Reattach the cap you previously set aside by rotating clockwise until secure.
Ziellinie
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Texas Tech, Team S9-G6, Cowan Fall 2020 Mitglied von Texas Tech, Team S9-G6, Cowan Fall 2020
TTU-COWAN-F20S9G6
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 26
Letzte 30 Tage: 125
Insgesamt: 3,827
