Zum Hauptinhalt wechseln
2018 Chevrolet Equinox Cabin Air Filter Replacement
Was du brauchst
  1. 2018 Chevrolet Equinox Cabin Air Filter Replacement, Cabin Air Filter: Schritt 1, Bild 1 von 2 2018 Chevrolet Equinox Cabin Air Filter Replacement, Cabin Air Filter: Schritt 1, Bild 2 von 2
    • Turn off vehicle air.
    • Find the glove box on the passenger side of the vehicle.
    • Open and remove all items from the glove box.
  2. 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 2, Bild 1 von 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 2, Bild 2 von 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 2, Bild 3 von 3
    • You will see a latch on the right side of the glove box.
    • Unhook the latch by gently pulling the latch outwards from the glove box.
  3. 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 3, Bild 1 von 2 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 3, Bild 2 von 2
    • Place your hands on the sides of the glove box.
    • Tightly squeeze the sides inward, and pull the glove box forward to detach the glove box from the dashboard.
  4. 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 4, Bild 1 von 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 4, Bild 2 von 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 4, Bild 3 von 3
    • The cabin air filter box has one 7/32" screw on each side.
    • Use a 7/32" nut driver to remove these two screws.
  5. 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 5, Bild 1 von 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 5, Bild 2 von 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 5, Bild 3 von 3
    • Plastic tabs will be right beneath the screws highlighted by markups.
    • Push the tabs in on both sides of the box simultaneously.
    • Lift the lid of the box to find the old cabin air filter.
  6. 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 6, Bild 1 von 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 6, Bild 2 von 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 6, Bild 3 von 3
    • Remove the filter, and check for debris in the filter box.
  7. 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 7, Bild 1 von 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 7, Bild 2 von 3 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 7, Bild 3 von 3
    • Place the new filter in the filter box.
    • The filter has an arrow, as indicated by the red box. Ensure that the arrow points down when placing the filter.
  8. 2018 Chevrolet Equinox Cabin Air Filter Replacement: Schritt 8, Bild 1 von 1
    • Pull the lid down and press both sides to close the filter box.
    • If you hear a clicking sound, then it means that the lid is closed.
Abschluss
To reassemble your glovebox, follow these instructions in reverse order.
Allan
157 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 18
Letzte 30 Tage: 109
Insgesamt: 2,745
