Einleitung
This guide will teach you how to replace the front windshield wipers of your 2022 Toyota RAV4.
Replacing your windshield wipers is more than routine maintenance – it is about enhancing your safety and driving experience. Worn-out wiper blades go beyond reducing visibility in bad weather; they can increase the risk of accidents. Imagine navigating through heavy rain or snow with impaired vision – well-maintained wiper blades ensure a clear line of sight.
But it is not just about safety. Worn blades can leave streaks, smudges, and water patches on the windshield, affecting your overall driving experience. The annoying sounds they make can disrupt the tranquility inside your vehicle. By replacing them promptly, you ensure a clear view, a quieter ride, and protect your windshield.
Before you begin, make sure your car is off and in park.
Was du brauchst
Insert a scraper or your fingers under the bottom part of the latch at the base of the wiper arm.
Gently lift the latch upward.
Hold the wiper blade just above the latch and gently slide the windshield wiper downward until there is no gap.
Tilt the windshield wiper blade at approximately a 30 degree angle and slide it upward.
Disengage and remove it from the wiper arm.
When reinstalling the wiper blade, position it perpendicular to the wiper arm. Ensure both components are straight and aligned.
Apply gentle pressure by pushing the blade downward toward the windshield, guiding it into the connection point.
Gently pull the windshield wiper upward, ensuring that there is a gap between the latch and the J hook.
Press the latch down to return it to its original position and lock the blade in place.
