Zum Hauptinhalt wechseln
2019-2022 Ford Ranger Headlight Replacement
Was du brauchst
  1. 2019-2022 Ford Ranger Headlight Replacement, Headlight: Schritt 1, Bild 1 von 2 2019-2022 Ford Ranger Headlight Replacement, Headlight: Schritt 1, Bild 2 von 2
    • Start the vehicle.
    • Turn the headlight dial to the "O" symbol to turn off the headlights.
    • Turn off vehicle.
    • Remove keys.
  2. 2019-2022 Ford Ranger Headlight Replacement: Schritt 2, Bild 1 von 2 2019-2022 Ford Ranger Headlight Replacement: Schritt 2, Bild 2 von 2
    • Pull the hood release to pop the vehicle's hood.
    • The hood release locates near the bottom of the driver side console below the headlight dial.
    • Push left and hold the yellow tab located under the middle of the hood.
    • Pull up on the hood.
    • Secure the hood open.
  3. 2019-2022 Ford Ranger Headlight Replacement: Schritt 3, Bild 1 von 3 2019-2022 Ford Ranger Headlight Replacement: Schritt 3, Bild 2 von 3 2019-2022 Ford Ranger Headlight Replacement: Schritt 3, Bild 3 von 3
    • Pry the 5 plastic fasteners out with a flathead or a spudger.
    • Remove the two screws anchoring the air intake vent with a flathead screw driver.
    • Lift the intake vent to make room to slide the cover out.
  4. 2019-2022 Ford Ranger Headlight Replacement: Schritt 4, Bild 1 von 3 2019-2022 Ford Ranger Headlight Replacement: Schritt 4, Bild 2 von 3 2019-2022 Ford Ranger Headlight Replacement: Schritt 4, Bild 3 von 3
    • Pry up along the edge of the cover with a flathead or a spudger to unclip it.
    • Listen for loud clicks as you pry up the edge. This indicates the clips are released.
    • Pull the cover off.
    • Set the cover aside.
    • The third photo is an example of vehicle with the cover removed.
  5. 2019-2022 Ford Ranger Headlight Replacement: Schritt 5, Bild 1 von 3 2019-2022 Ford Ranger Headlight Replacement: Schritt 5, Bild 2 von 3 2019-2022 Ford Ranger Headlight Replacement: Schritt 5, Bild 3 von 3
    • Remove the 10mm bolts that anchor the grill to the frame with a socket wrench.
    • Use the socket wrench with the 10mm hex attachment
  6. 2019-2022 Ford Ranger Headlight Replacement: Schritt 6, Bild 1 von 3 2019-2022 Ford Ranger Headlight Replacement: Schritt 6, Bild 2 von 3 2019-2022 Ford Ranger Headlight Replacement: Schritt 6, Bild 3 von 3
    • Using the T-25 Torx bit, unscrew the secondary cover from the frame.
    • There are 4 total screws on each of the corners of the cover.
  7. 2019-2022 Ford Ranger Headlight Replacement: Schritt 7, Bild 1 von 2 2019-2022 Ford Ranger Headlight Replacement: Schritt 7, Bild 2 von 2
    • Remove the secondary cover by shift and pulling it up with you hands.
    • The cover is not very flexible; remove slowly to reduce risk of breaking it.
  8. 2019-2022 Ford Ranger Headlight Replacement: Schritt 8, Bild 1 von 3 2019-2022 Ford Ranger Headlight Replacement: Schritt 8, Bild 2 von 3 2019-2022 Ford Ranger Headlight Replacement: Schritt 8, Bild 3 von 3
    • Push down on the plastic clips to release them.
    • Push outwards on the outer clips to release them.
    • Pull the grill directly towards you once the all clips are released.
    • These clips are plastic and brittle. Be patient to make sure they do not break.
    • Removing the grill will take considerably longer than other steps since clips on one side have a tendency to snap back in once you move to the other.
  9. 2019-2022 Ford Ranger Headlight Replacement: Schritt 9, Bild 1 von 3 2019-2022 Ford Ranger Headlight Replacement: Schritt 9, Bild 2 von 3 2019-2022 Ford Ranger Headlight Replacement: Schritt 9, Bild 3 von 3
    • Remove hardware that is anchoring down the head light using 10 mm hex bit.
    • Remove hardware that is anchoring down the head light using Philips head 2 screwdriver.
  10. 2019-2022 Ford Ranger Headlight Replacement: Schritt 10, Bild 1 von 3 2019-2022 Ford Ranger Headlight Replacement: Schritt 10, Bild 2 von 3 2019-2022 Ford Ranger Headlight Replacement: Schritt 10, Bild 3 von 3
    • Remove wheel well lining to expose space under headlight.
    • Pry out side hazard light using a flat head screwdriver or spudger.
    • Remove T-25 torx screw.
  11. 2019-2022 Ford Ranger Headlight Replacement: Schritt 11, Bild 1 von 1
    • Pull away the fender guard to expose the last bolt the anchors the headlight to the body.
    • Pulling back the fender guard will require the release of a clip the was underneath the wheel-well liner.
    • Remove bolt using the 7mm hex bit.
  12. 2019-2022 Ford Ranger Headlight Replacement: Schritt 12, Bild 1 von 2 2019-2022 Ford Ranger Headlight Replacement: Schritt 12, Bild 2 von 2
    • Pull out the headlight.
    • Unplug the headlight cable.
Abschluss
Long Phuoc Tran
205 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 39
Letzte 30 Tage: 156
Insgesamt: 3,898
