Zum Hauptinhalt wechseln
2019 Chevrolet Colorado Windshield Wiper Replacement
Was du brauchst
  1. 2019 Chevrolet Colorado Windshield Wiper Replacement, Windshield Wiper: Schritt 1, Bild 1 von 1
    • Identify where the buttons are on the windshield wipers are.
    • Once the buttons are identified make note of where they are located on both wipers because of the different sizes they are slightly different on each.
  2. 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 2, Bild 1 von 2 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 2, Bild 2 von 2
    • Lift the drive side wiper up so that it is no longer touching the windshield.
    • This allows you to have better access to the wipers.
  3. 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 3, Bild 1 von 2 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 3, Bild 2 von 2
    • Disconnect the blade on the driver side by pushing the small button down in order to release the wiper.
  4. 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 4, Bild 1 von 3 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 4, Bild 2 von 3 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 4, Bild 3 von 3
    • Slowly slide the wiper off of the wiper arm by pulling it back and away from the windshield.
    • The wiper arm is like a hook so make sure that you completely unhook the metal piece from the wiper blade.
    • Follow the direction of the arrows.
  5. 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 5, Bild 1 von 3 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 5, Bild 2 von 3 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 5, Bild 3 von 3
    • Repeat steps 1-4 on the passenger side wiper.
  6. 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 6, Bild 1 von 2 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 6, Bild 2 von 2
    • Grab the 22" wiper blade and position it on the wiper arm so that it is hooked into places as well as flush with the arm.
  7. 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 7, Bild 1 von 3 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 7, Bild 2 von 3 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 7, Bild 3 von 3
    • Pull the wiper blade down with your right hand and slowly push with your left onto the wiper arm until you hear it snap back into place.
    • Make sure that the wiper is securely fastened and that it cannot be removed without pushing the button.
    • Follow the direction of the arrow.
  8. 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 8, Bild 1 von 3 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 8, Bild 2 von 3 2019 Chevrolet Colorado Windshield Wiper Replacement: Schritt 8, Bild 3 von 3
    • Repeat steps 6 and 7 on the passenger side wiper. Make sure you are using the 18" wiper for the passenger side replacement.
Abschluss
to reassemble your device, follow these instructions in reverse order
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 16
Letzte 30 Tage: 73
Insgesamt: 3,540
