Einleitung
Replacing your interior air filter is essential to ensure that the air inside your vehicle is clean and free of contaminants. This guide will walk you through the process of replacing the interior air filter in your 2019 Mitsubishi Mirage, a task that can be accomplished in just a few simple steps and requires no special tools.
By performing these steps, you can ensure that your Mitsubishi Mirage has a clean air filter, which will help keep the air in your vehicle fresh and reduce allergens and contaminants. This simple maintenance task can significantly impact the comfort and health of your vehicle's occupants.
Was du brauchst
Locate the glove box near the front passenger seat in the vehicle.
Look at the top left and right of the glovebox. Here, you will see tabs attached to both sides.
Using both hands, push each side of the glove box inward, making the tabs unfasten from their designated clips. The glove box will now fold down.
Place a new air filter inside the cabin air filter compartment right side up.
Replace the cabin air filter cover. Ensure that the cover is slid on correctly and that the safety clip is secured on the right before moving on.
Grab both sides of the glove box near the top just as you did in step 3.
Push the tabs inward and push the glove box back into place.
Ensure the tabs are secured in their designated clips before closing the glove box.
2 weitere Personen haben diese Anleitung absolviert.
