Zum Hauptinhalt wechseln
2019 Toyota Highlander Cabin Air Filter Replacement
  1. 2019 Toyota Highlander Cabin Air Filter Replacement, Cabin Air Filter: Schritt 1, Bild 1 von 2 2019 Toyota Highlander Cabin Air Filter Replacement, Cabin Air Filter: Schritt 1, Bild 2 von 2
    • Open the glove compartment and take everything out.
  2. 2019 Toyota Highlander Cabin Air Filter Replacement: Schritt 2, Bild 1 von 3 2019 Toyota Highlander Cabin Air Filter Replacement: Schritt 2, Bild 2 von 3 2019 Toyota Highlander Cabin Air Filter Replacement: Schritt 2, Bild 3 von 3
    • Press the tabs on the sides of the glove compartment until they are released.
    • Please press the sides gently to avoid any damage.
  3. 2019 Toyota Highlander Cabin Air Filter Replacement: Schritt 3, Bild 1 von 1
    • Once the tabs are released, remove the entire glove compartment.
  4. 2019 Toyota Highlander Cabin Air Filter Replacement: Schritt 4, Bild 1 von 3 2019 Toyota Highlander Cabin Air Filter Replacement: Schritt 4, Bild 2 von 3 2019 Toyota Highlander Cabin Air Filter Replacement: Schritt 4, Bild 3 von 3
    • Open the second cover. Position your finger where the red circle is pointing in the first image, then lower it.
  5. 2019 Toyota Highlander Cabin Air Filter Replacement: Schritt 5, Bild 1 von 3 2019 Toyota Highlander Cabin Air Filter Replacement: Schritt 5, Bild 2 von 3 2019 Toyota Highlander Cabin Air Filter Replacement: Schritt 5, Bild 3 von 3
    • Press the tabs on the side of the third cover. Remove the cover.
    • Do not apply heavy force to prevent damage.
  6. 2019 Toyota Highlander Cabin Air Filter Replacement: Schritt 6, Bild 1 von 3 2019 Toyota Highlander Cabin Air Filter Replacement: Schritt 6, Bild 2 von 3 2019 Toyota Highlander Cabin Air Filter Replacement: Schritt 6, Bild 3 von 3
    • Pull the filter out. If the filter is really dirty, then replace it with a new one. Otherwise, clean the filter and return it to position.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
York University, Team S2-G7, O'Regan Winter 2021 Mitglied von York University, Team S2-G7, O'Regan Winter 2021
YORK-O'REGAN-W21S2G7
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 48
Letzte 30 Tage: 214
Insgesamt: 4,905
