Einleitung
This guide will demonstrate how to replace/clean the interior air filter for the 2019 Toyota Highlander. This replacement does not require any tools, only your hands, which makes this fix guide easier to follow. By changing the air filter on your own, you can save some time and money.
Open the second cover. Position your finger where the red circle is pointing in the first image, then lower it.
Pull the filter out. If the filter is really dirty, then replace it with a new one. Otherwise, clean the filter and return it to position.
2 weitere Personen haben diese Anleitung absolviert.
