Zum Hauptinhalt wechseln
2020 Toyota Sienna Key Fob Battery Replacement
Was du brauchst
  1. 2020 Toyota Sienna Key Fob Battery Replacement, Key Fob Battery: Schritt 1, Bild 1 von 3 2020 Toyota Sienna Key Fob Battery Replacement, Key Fob Battery: Schritt 1, Bild 2 von 3 2020 Toyota Sienna Key Fob Battery Replacement, Key Fob Battery: Schritt 1, Bild 3 von 3
    • Position the battery on its side where the "Push" button is.
    • Click down on the "Push" button.
    • Pull out the physical key at the top of the fob on the same side as the "Push" button is located.
  2. 2020 Toyota Sienna Key Fob Battery Replacement: Schritt 2, Bild 1 von 3 2020 Toyota Sienna Key Fob Battery Replacement: Schritt 2, Bild 2 von 3 2020 Toyota Sienna Key Fob Battery Replacement: Schritt 2, Bild 3 von 3
    • Place the tip of a spudger in the slotted area and twist to pry the fob open.
    • Separate the two sides of the fob carefully.
  3. 2020 Toyota Sienna Key Fob Battery Replacement: Schritt 3, Bild 1 von 3 2020 Toyota Sienna Key Fob Battery Replacement: Schritt 3, Bild 2 von 3 2020 Toyota Sienna Key Fob Battery Replacement: Schritt 3, Bild 3 von 3
    • Lay out the two sides of the fob with the interior of the fob facing you.
    • Remove the battery from the key fob.
    • Carefully insert the new battery in the battery placeholder.
  4. 2020 Toyota Sienna Key Fob Battery Replacement: Schritt 4, Bild 1 von 2 2020 Toyota Sienna Key Fob Battery Replacement: Schritt 4, Bild 2 von 2
    • Grab the other side of the key fob and make sure they're aligned with each other before snapping them back together.
    • Carefully close them together.
    • You should hear a click once closed.
  5. 2020 Toyota Sienna Key Fob Battery Replacement: Schritt 5, Bild 1 von 2 2020 Toyota Sienna Key Fob Battery Replacement: Schritt 5, Bild 2 von 2
    • Grab the physical key and insert it back into its place.
    • Now the battery has been replaced and you are good to go!
Ziellinie
Mariana
121 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 59
