Einleitung
In this guide, I will walk you through how to change your oil and replace your oil filter on a 2020 Yamaha R3. First gathering your tools, oil, oil filter, and don’t forget to grab your gloves it may get messy! Give yourself enough room to work on your bike.
Was du brauchst
Remove the bolt underneath the bike with a wrench and 12 mm socket.
Let the bike sit and drain all of the oil.
Twist the oil filter counterclockwise to remove it.
Dump the oil into the oil pan.
Let the bike sit for a few minutes to let all the oil drain from the bike.
Remove the oil cap from the side of the bike.
Place a funnel into the oil tank.
Slowly pour between 2.2-2.5 US quarts of oil into the tank.
Hold your bike up straight to view the oil lines on the side of the bike.
Let the bike run for a few minutes to allow oil to flow through bike. After this, you may need to add more oil.
I hope this guide was helpful in walking you through the replacement of your oil and oil filter in a Yamaha R3.
3 weitere Personen haben diese Anleitung absolviert.
