Zum Hauptinhalt wechseln
2021 Honda HR-V Rear Signal Light Bulb Replacement
Was du brauchst
  1. 2021 Honda HR-V Rear Signal Light Bulb Replacement, Rear Signal Light Bulb: Schritt 1, Bild 1 von 1
    • Press the tailgate release button and lift open the rear hatch.
  2. 2021 Honda HR-V Rear Signal Light Bulb Replacement: Schritt 2, Bild 1 von 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: Schritt 2, Bild 2 von 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: Schritt 2, Bild 3 von 3
    • Remove the two screws beside each tail light assembly (four total) using a Phillips #1 screwdriver.
  3. 2021 Honda HR-V Rear Signal Light Bulb Replacement: Schritt 3, Bild 1 von 2 2021 Honda HR-V Rear Signal Light Bulb Replacement: Schritt 3, Bild 2 von 2
    • Place both hands on the tail light assembly and pull it directly outwards (away from the vehicle).
    • The tail light assembly will still be connected to the vehicle by wiring, so make sure to be careful when pulling the light assembly out.
  4. 2021 Honda HR-V Rear Signal Light Bulb Replacement: Schritt 4, Bild 1 von 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: Schritt 4, Bild 2 von 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: Schritt 4, Bild 3 von 3
    • Remove the rear signal light bulb from the light assembly by rotating the bulb socket counterclockwise.
  5. 2021 Honda HR-V Rear Signal Light Bulb Replacement: Schritt 5, Bild 1 von 2 2021 Honda HR-V Rear Signal Light Bulb Replacement: Schritt 5, Bild 2 von 2
    • Pull apart the light bulb from its socket.
    • Replace with a new light bulb and apply pressure to ensure the light bulb is securely fastened.
  6. 2021 Honda HR-V Rear Signal Light Bulb Replacement: Schritt 6, Bild 1 von 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: Schritt 6, Bild 2 von 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: Schritt 6, Bild 3 von 3
    • Slide the light assembly into the raised white plastic attached to the vehicle.
    • Align the holes on the light assembly to the holes on the vehicle and fasten the bolts into position.
Ziellinie
Guadalupe Guevara
133 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 2-8, Briggs Fall 2022 Mitglied von CSU Los Angeles, Team 2-8, Briggs Fall 2022
CSULA-BRIGGS-F22S2G8
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 54
Insgesamt: 1,089
