Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Is the screen of your Hisense 32" TV having some issues and getting someone to replace it would cost a fortune? Try using this guide to fix it yourself!
  1. DO NOT plug the TV into power at any time during this process. To begin, lay the TV screen-down on a smooth surface.
    • DO NOT plug the TV into power at any time during this process.
    • To begin, lay the TV screen-down on a smooth surface.
    • Unscrew the screws connecting both support legs to the TV.
  2. To begin removing the back plate, find and remove all 18 screws indicated with the Phillips screwdriver. If the screws are difficult to find, remove any screws on the back plate that have an arrow pointing to them like in the second picture.
    • To begin removing the back plate, find and remove all 18 screws indicated with the Phillips screwdriver.
    • If the screws are difficult to find, remove any screws on the back plate that have an arrow pointing to them like in the second picture.
    • Once all of the screws are removed, carefully pop off the back plate without damaging any of the connected wires.
  3. Slide the power cord free from its metal framework.
    • Slide the power cord free from its metal framework.
    • After the power cord has been moved, remove the four screws keeping the housing in place. Once finished, remove the housing as well.
  4. Remove the three silver screws connecting the circuit board to the rest of the TV that are circled in the picture using the Phillips screwdriver. Remove the final silver screw, making sure to avoid disconnecting any of the wires that obscure it from view.
    • Remove the three silver screws connecting the circuit board to the rest of the TV that are circled in the picture using the Phillips screwdriver.
    • Remove the final silver screw, making sure to avoid disconnecting any of the wires that obscure it from view.
  5. Remove all of the 18 screws connecting the front frame to the back of the TV with the Torx screwdriver.
    • Remove all of the 18 screws connecting the front frame to the back of the TV with the Torx screwdriver.
  6. Once the screws are all removed, slide the flat-head screwdriver into the small gap between the front and back plates. Use the screwdriver to pry the plates apart and lift the back plate up.
    • Once the screws are all removed, slide the flat-head screwdriver into the small gap between the front and back plates. Use the screwdriver to pry the plates apart and lift the back plate up.
  7. Completely separate the back from the front and flip the back section over so that the screen is now on top.
    • Completely separate the back from the front and flip the back section over so that the screen is now on top.
  8. Find the cable pictured and detach the plastic film protecting the circuitry to which the cable is attached.
    • Find the cable pictured and detach the plastic film protecting the circuitry to which the cable is attached.
    • DO NOT detach both ends of the plastic. Only detach the end that is easily removed from its adhesive.
  9. After detaching the plastic, detach the wire connecting the screen to the rest of the TV.
    • After detaching the plastic, detach the wire connecting the screen to the rest of the TV.
    • Next, the circuitry needs to be removed from the TV itself. Lift the screen circuitry free from the adhesive and then lift the screen free from the back section of the TV.
  10. Now that the screen has been removed, take the new screen and attach its circuitry in the same place as the previous screen. After that, connect the cable from the rest of the TV to the screen's port and it should be good to go! Now that the screen has been removed, take the new screen and attach its circuitry in the same place as the previous screen. After that, connect the cable from the rest of the TV to the screen's port and it should be good to go!
    • Now that the screen has been removed, take the new screen and attach its circuitry in the same place as the previous screen. After that, connect the cable from the rest of the TV to the screen's port and it should be good to go!
Abschluss
17 weitere Nutzer haben diese Anleitung absolviert.
Connor French
1.166 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 17-2, Green Fall 2015 Mitglied von Cal Poly, Team 17-2, Green Fall 2015
CPSU-GREEN-F15S17G2
4 Mitglieder
7 Anleitungen geschrieben
Where can I buy the replacement panel?
Arinah Arin - Antwort
Could you please post the panel code of this tv model (32H3C)? I guess it could be the same my hisense tv need . It could help me to find the right spare part.
Thx
Alexis - Antwort
where can i buy Hisene LCD TV Screen pls?
H Te Tea - Antwort
where do I buy a replacement screen for 32inch hisence smart tv
Shaik Ahmed Khaleck - Antwort
How can I buy the 55inch screen. The straight TV not curve
Solomon - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 18
Letzten 7 Tage: 113
Letzten 30 Tage: 451
Insgesamt: 29,044
