Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
This page will guide you on the replacement of the battery on your 360fly 4K camera.
  1. Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
  2. Remove the two 5mm T4 screws from the bottom of the camera with a t4 screw driver.
    • Remove the two 5mm T4 screws from the bottom of the camera with a t4 screw driver.
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. Gently pry the plastic ring from around the charging plate with the metal spudger. Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
  5. Remove the five 2mm T4 screws and pull off the charging plate assmebly with the t4 screw driver.
    • Remove the five 2mm T4 screws and pull off the charging plate assmebly with the t4 screw driver.
  6. Gently pry the plug off the port on the circuit board with a plastic opening tool. Remove the four 2mm T4 screws and take off the circuit board with a T4 screw driver.
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2mm T4 screws and take off the circuit board with a T4 screw driver.
  7. Remove the five 4mm T4 screws around the battery assembly with a t4 crew driver. Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool. Press the battery from the back  of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Remove the five 4mm T4 screws around the battery assembly with a t4 crew driver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Jacob Herron
421 Reputation
3 Anleitungen geschrieben
IUPUI, Team S5-G3, Baechle Fall 2017 Mitglied von IUPUI, Team S5-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G3
3 Mitglieder
Wich one battery Can I use to replace It?
Marco Pereira - Antwort
Where can i purchase a battery
john hernandez - Antwort
I would like to purchase a 360 fly battery
Where can I buy the battery?
Mark - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 40
Insgesamt: 1,121
