Einleitung
This guide walks you through how to replace the SD memory card on a 360fly 4K camera.
Was du brauchst
Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
Gently pry the plastic ring from around the charging plate with the metal spudger.
Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
Remove the five 2 mm screws using a T4 screwdriver.
Pull off the charging plate assembly.
Gently pry the plug off the port on the circuit board with a plastic opening tool.
Remove the four 2 mm screws using a T4 screwdriver.
Remove the circuit board from the device.
Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
Gently pry the plug from the motherboard and remove the motherboard from the assembly.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
