Was du brauchst
Remove the eight 11mm screws attaching the underbody of the drone using the 2mm Hex screwdriver/key.
Remove the two larger, 12mm screws attached to the Go Pro mount using the 3mm Hex screwdriver/key.
Lift to remove the mount.
Feed both wires through the grill of the bottom shell.
Lift to remove the shell.
Fast fertig!
Abschluss
