Einleitung
The gimbal allows for the rotation of an object such as a camera. If your gimbal is experiencing malfunctions such as gimbal overload, lack of rotation, abnormal vibrations, etc., follow this guide to remove the gimbal and replace the part.
Was du brauchst
If your drone is equipped with it, remove the video transmitter.
Disconnect all cables from the gimbal.
If your drone has neither the gimbal or video transmitter, you can skip this step.
Unscrew the 16 mm screw attaching the gimbal mount to the body of the drone using the 3 mm Hex screwdriver/key.
Rotate the drone 180 degrees.
Unscrew the other 16mm gimbal mount screw using the 3 mm Hex screwdriver/key.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
Where are the two wires connect to the gimbal one is a ground and the white wire connects to the power, but where?
