Was du brauchst
With the back plate off, remove the three 4mm screws using the Hex 2 mm screwdriver. These secure the top plate to the drone assembly.
Rotate the drone 180 degrees (top facing up) and remove the top plate from the drone.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
