Einleitung
Use this guide to learn how to replace the massage motors and wire harness in the Infinity IT-8500 massage chair. If your massage motors are actuating incorrectly, the massage motors stop moving like they used to, or the entire motor stops movement completely, it may be time to replace the massage mechanism in your chair.
Was du brauchst
The back cover is covered by this leather cover. which unzips easily.
Zipper is located here and there are 2 of these on either side.
Press Down on Latch between armrest and chair body .
What the result should look like.
Note the speaker bracket will need be threaded through its leather slot and left hanging inside the back of the chair.
Now we need to disconnect the wire harness from the mechanism . Do this by simply unplugging the marked cables
When replacing the wire harness you need to disconnect the upper portion of the harness from the mechanism and then locate the quick disconnect .
Quick disconnect
Remove the 3 screws
These are the locations of the the wires for the lower harness
2 Kommentare
Infinity IT 8500 Massage Chair Remote , Anyone know the pin out on the 8-pin control panel dim? My pup chewed through it and of course It was thrown out ASAP RandyC
