Zum Hauptinhalt wechseln
8BitDo SN30 Pro+ Controller Buttons Replacement
Was du brauchst
  1. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Battery: Schritt 1, Bild 1 von 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Battery: Schritt 1, Bild 2 von 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Battery: Schritt 1, Bild 3 von 3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
  2. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Trigger Buttons: Schritt 2, Bild 1 von 2 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Trigger Buttons: Schritt 2, Bild 2 von 2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
  3. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: Schritt 3, Bild 1 von 2 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
  4. 8BitDo SN30 Pro+ Controller Buttons Replacement, Unclip Covers: Schritt 4, Bild 1 von 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Unclip Covers: Schritt 4, Bild 2 von 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Unclip Covers: Schritt 4, Bild 3 von 3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
  5. 8BitDo SN30 Pro+ Controller Buttons Replacement, Separate Covers: Schritt 5, Bild 1 von 1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
  6. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Ribbon Cable: Schritt 6, Bild 1 von 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Ribbon Cable: Schritt 6, Bild 2 von 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Ribbon Cable: Schritt 6, Bild 3 von 3
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
  7. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: Schritt 7, Bild 1 von 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: Schritt 7, Bild 2 von 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Screws: Schritt 7, Bild 3 von 3
    • Use a Phillips screwdriver to remove the seven screws securing the main circuit board.
    • Six 10.1mm screws
    • One 5.8mm screws
  8. 8BitDo SN30 Pro+ Controller Buttons Replacement, Separate Main Board: Schritt 8, Bild 1 von 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Separate Main Board: Schritt 8, Bild 2 von 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Separate Main Board: Schritt 8, Bild 3 von 3
    • Slide the R buttons up and off its peg.
    • Slide the L button up and off its peg.
    • Remove the main board by rotating it towards the USB-C port. Then lift it out.
  9. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Rubber Pads: Schritt 9, Bild 1 von 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Rubber Pads: Schritt 9, Bild 2 von 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Rubber Pads: Schritt 9, Bild 3 von 3
    • Use a pair of tweezers or your fingers to remove the five silicone rubber pads.
    • Three black conductive pads.
    • Two clear pads.
    • During reassembly, make sure AXBY conductive rubber has the cut out on the top.
  10. 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Buttons: Schritt 10, Bild 1 von 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Buttons: Schritt 10, Bild 2 von 3 8BitDo SN30 Pro+ Controller Buttons Replacement, Remove Buttons: Schritt 10, Bild 3 von 3
    • Use a pair of tweezers or your fingers to remove the buttons you wish to replace.
    • The Home button is two parts: the center button and the outer clear ring.
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
Brian W
1.773 Reputation
8 Anleitungen geschrieben
4 Kommentare zur Anleitung
Hi, it looks like the buttons have little notches that limit where they can go. I was really hoping to modify it so that my a button is green and my b is red would that work if I file down that little notch?
Will Platt - Antwort
The buttons are all the same height, so feel free to file down. Those nubs are just part of assemble process.
But do leave the 2 longer stems on each side of the button, they stop it from rotating freely.
Brian W -
I just completed this guide, and it is 100% perfection. The photos are useful and clear, and explanations are on point. Many thanks.
Chris Zirker - Antwort
I especially appreciate mention of screw length as I'm prone to mixing them up. Lovely guide 🫠
Joshua Napier - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 23
Letzte 30 Tage: 122
Insgesamt: 10,375
