Zum Hauptinhalt wechseln
8BitDo SN30 Pro+ Controller Triggers Replacement
Was du brauchst
  1. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: Schritt 1, Bild 1 von 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: Schritt 1, Bild 2 von 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Battery: Schritt 1, Bild 3 von 3
    • Place the controller face down.
    • Remove the battery cover.
    • Remove rechargeable battery or AA batteries.
    Frag FixBot
    Kommentar hinzufügen
  2. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Buttons: Schritt 2, Bild 1 von 2 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Buttons: Schritt 2, Bild 2 von 2
    • Remove L2 and R2 trigger buttons by pushing them away from the grips.
    Frag FixBot
  3. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: Schritt 3, Bild 1 von 2 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use Tweezers to uncover two screws under the label in the battery compartment.
    • Use a T6 screwdriver to remove the four 7.3 mm screws securing the rear cover.
    Frag FixBot
  4. 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: Schritt 4, Bild 1 von 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: Schritt 4, Bild 2 von 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Unclip Covers: Schritt 4, Bild 3 von 3
    • At the end of each grip, pry apart the covers.
    • Use fingernail or opening pick to undo the two top clips.
    • One clip next to L button.
    • One clip next to R button
    • Undo the final clip between the joysticks.
    Frag FixBot
  5. 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Covers: Schritt 5, Bild 1 von 1
    • Carefully move the rear cover away and from the front cover. Place it to the left.
    • Do not completely separate. The two halves are still attached via a white ribbon cable.
    Frag FixBot
  6. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: Schritt 6, Bild 1 von 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: Schritt 6, Bild 2 von 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Ribbon Cable: Schritt 6, Bild 3 von 3
    • Unlock the ribbon cable by push open the black plastic tab.
    • The tab will slide about 1.5mm
    • Pull the ribbon cable out of the connector in the direction of the cable.
    Frag FixBot
  7. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: Schritt 7, Bild 1 von 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: Schritt 7, Bild 2 von 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Screws: Schritt 7, Bild 3 von 3
    • Use a Phillips screwdriver to remove the seven screws securing the main circuit board.
    • Six 10.1mm screws
    • One 5.8mm screws
    Frag FixBot
  8. 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: Schritt 8, Bild 1 von 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: Schritt 8, Bild 2 von 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Separate Main Board: Schritt 8, Bild 3 von 3
    • Slide the R buttons up and off its peg.
    • Slide the L button up and off its peg.
    • Remove the main board by rotating it towards the USB-C port. Then lift it out.
    Frag FixBot
  9. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: Schritt 9, Bild 1 von 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: Schritt 9, Bild 2 von 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger Assembly: Schritt 9, Bild 3 von 3
    • Release the three clips holding the trigger assembly to the main board.
    • Repeat with the other side.
    Frag FixBot
  10. 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: Schritt 10, Bild 1 von 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: Schritt 10, Bild 2 von 3 8BitDo SN30 Pro+ Controller Triggers Replacement, Remove Trigger: Schritt 10, Bild 3 von 3
    • Bend the plastic tab over the locking hook. It helps to push the trigger back slightly, with your other hand.
    • Gently pry the each side of the trigger out of the round clips.
    • Both conductive pads are now accessible.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Brian W
1.800 Reputation
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 103
Insgesamt: 4,739
