Zum Hauptinhalt wechseln
A Jammed SD Card Tray
Was du brauchst
  1. A Jammed SD Card Tray, A Jammed SD Card Tray: Schritt 1, Bild 1 von 2 A Jammed SD Card Tray, A Jammed SD Card Tray: Schritt 1, Bild 2 von 2
    • As you see the sd tray is bent in.
    • And you can’t get it open like usual.
  2. A Jammed SD Card Tray, Popping up tray: Schritt 2, Bild 1 von 2 A Jammed SD Card Tray, Popping up tray: Schritt 2, Bild 2 von 2
    • Pop up the sd port tray
  3. A Jammed SD Card Tray, Popping open tray: Schritt 3, Bild 1 von 3 A Jammed SD Card Tray, Popping open tray: Schritt 3, Bild 2 von 3 A Jammed SD Card Tray, Popping open tray: Schritt 3, Bild 3 von 3
    • Here is the tool you need or something similar
    • PLEASE BE CAREFUL IT CAN DAMAGE THE EXPOSED MOTHERBOARD INSIDE IF NOT
  4. A Jammed SD Card Tray, Remove sd card: Schritt 4, Bild 1 von 3 A Jammed SD Card Tray, Remove sd card: Schritt 4, Bild 2 von 3 A Jammed SD Card Tray, Remove sd card: Schritt 4, Bild 3 von 3
    • You have to press down on sd like the physical game to get it out
    • And don’t forget to close the tray
Abschluss
Thanks and you’re welcome now you have free access to your sd card!
Sqwerks
512 Reputation
1 Anleitung geschrieben
Oregonians Mitglied von Oregonians
Community
7 Mitglieder
176 Anleitungen geschrieben
4 Kommentare
My first guide 😂
Sqwerks - Antwort
its been officially accepted as of two months ago yahoo
Sqwerks - Antwort
also i sold the 3ds to @tronicsfix (if your reading this sorry) but yea (just so you know I'm here as well)
Sqwerks - Antwort
it was by wild chance even though they are my main inspiration and got me into ifixit
Sqwerks - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 56
Insgesamt: 722
