Zum Hauptinhalt wechseln
ABXY/D-pad Conductive Sticker Replacement
Was du brauchst
  1. ABXY/D-pad Conductive Sticker Replacement, Back Cover Removal Preparation: Schritt 1, Bild 1 von 1
    • Before starting the disassembly, remove
    • The stylus
    • Any game cartridge
    • The SD card
  2. ABXY/D-pad Conductive Sticker Replacement, Back Cover Removal: Schritt 2, Bild 1 von 1
    • Unscrew the four 6mm tri-point screws located at the four corners of the bottom panel.
  3. ABXY/D-pad Conductive Sticker Replacement, Case Separation: Schritt 3, Bild 1 von 2 ABXY/D-pad Conductive Sticker Replacement, Case Separation: Schritt 3, Bild 2 von 2
    • Be careful when separating the bottom panel from the front casing to avoid breaking the three cables connected to the motherboard (two on each side and one in the rear).
    • Using a spudger, separate the back panel from the front casing by gently prying around the panel.
    • There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
  4. ABXY/D-pad Conductive Sticker Replacement: Schritt 4, Bild 1 von 3 ABXY/D-pad Conductive Sticker Replacement: Schritt 4, Bild 2 von 3 ABXY/D-pad Conductive Sticker Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Using tweezers, disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
  5. ABXY/D-pad Conductive Sticker Replacement, Battery Removal: Schritt 5, Bild 1 von 2 ABXY/D-pad Conductive Sticker Replacement, Battery Removal: Schritt 5, Bild 2 von 2
    • Using a spudger, lift out the battery.
    • Be aware that there is a sticky pad holding the battery into its tray. It may be necessary to use multiple tools to gently pry the battery away from the tray and motherboard.
  6. ABXY/D-pad Conductive Sticker Replacement, Motherboard: Schritt 6, Bild 1 von 2 ABXY/D-pad Conductive Sticker Replacement, Motherboard: Schritt 6, Bild 2 von 2
    • There are 8 ribbon cables that need to be removed as shown in the picture.
    • 2 of connectors (in green) are friction fit, unlike the rest of the connectors. Remove the cable by pulling it out gently. Do not attempt to open or unlatch these connectors in any way. Doing so will break them.
    • For the remaining 6 (in red), use a pair of tweezers to flip the latches up and pull the ribbon cable out.
    • Note that the second picture shows a broken ribbon connector next to the joystick ribbon connector (to the right of the red arrow). Do not attempt to unlatch this connector as shown in the picture!
  7. ABXY/D-pad Conductive Sticker Replacement: Schritt 7, Bild 1 von 2 ABXY/D-pad Conductive Sticker Replacement: Schritt 7, Bild 2 von 2
    • Unplug the following wires from the motherboard using a pair of tweezers.
  8. ABXY/D-pad Conductive Sticker Replacement: Schritt 8, Bild 1 von 2 ABXY/D-pad Conductive Sticker Replacement: Schritt 8, Bild 2 von 2
    • Remove the seven 4.4 mm screws using a J00 (or iFixit's Phillips #00) screwdriver bit.
    • Remove the motherboard from the device.
  9. ABXY/D-pad Conductive Sticker Replacement, ABXY/D-pad Conductive Sticker: Schritt 9, Bild 1 von 1
    • Flip the board over so the cartridge slot is on the bottom
    • Peel off the damaged sticker and replace it with the new one
    • ABXY buttons
    • D-pad
    • If the new sticker doesn't fit properly, you can cut it apart and stick each pad down separately. As long as they're properly aligned and secure, the buttons will still work normally
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
darth mango
3.107 Reputation
3 Anleitungen geschrieben
Kid fixers Mitglied von Kid fixers
Community
188 Mitglieder
273 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 51
Letzte 30 Tage: 183
Insgesamt: 2,581
